BargainBrad
Member
Mbz, good news to report.
I reinstalled the rebuilt power supply board last night and started it up without the power amp board installed and with a dim bulb tester attached.
The power supply board operated perfectly and was generating the correct voltage (around 48V) and there was no short. The bulb when bright for just a second and then completely dark.
This means the problem is on the power amp board for use.
I am going to lower the trimmer resistance as low as possible tonight, check the diodes one more time, and then give it another run.
Worse case scenario, if something doesn't work, at least it will give me a clue as to where the problem on the board is.
I will not install the outputs yet and will report back tomorrow.
Let's hope for the best.
