I build the Leak TL/50 from scratch, point to point, following the schematic. Some of the voltages are a bit
high: EF86 165 (should be 150); 12ax7 315v (should be 300) Kt88 plates 478- cathode to plate voltage 425v.
across cathode 45v ;resistor ohms 493. The treble is wonderful but the bass is weak, very weak. I upgrade the coupling cap from .25 to .47uf, along with the screen grid cap on 12ax7. But still very little bass. Now I am a novice. the only tool I have is a multimeter. Please, no complex theory. Any help to improve the bass will be
appreciated. schematic link: http://www.44bx.com/leak/Leak/Circuits/tl50_ecc83.JPG
