HELP Original Large Advents Bass Hiss
Giang Le
AK Subscriber
Hi everyone, I recently bought a pair of Original Large Advents and evertime the bass becomes deep or a loud bass note hits the tweeters would distort or hisses slightly? Whats seems to be the problem, should I replace the tweeters?
Are all the drivers bolted in tight?
Yes all drivers are presently bolted on as tight as they will go. I notice that the tweeter seems to be diffrent from the other models I have seen on google images, was it modified to you?
Make sure there is some sort of gasket between the drivers and enclosure.
ANY air leaks, no matter how small, will have a negative impact on speaker performance.
I have used More-tite rope caulk for this purpose. Available at most hardware/home improvement stores for $5- $10.
That tweeter doesn't look like it's mounted correctly on the plate.
That tweeter has been altered in some way. The angle between the two rectangles is not correct and the wire cage is missing. The missing cage might be your culprit. I would replace the tweeters. Do they both look like that?
They should look like this.
Has anything been replaced in the crossovers?
Unless they are from an early production run. The first Large Advents did not have protective cages. The angle may be correct as well.
Example of an early tweeter:
I believe that to be true, although I had never seen one until now. I read it somewhere, but the uncaged tweeters rattled and were replaced with the caged model shortly after production started.
They were also fragile and extremely easy to damage. Advent offered to send cages so customers could install them for added protection. This was before Advent started manufacturing the tweeters with the mesh cage.
Thanks for the help everyone, I think it might be the tweeters inherent problems being a early production model. I am currently running it with my Sansui G901DB (G9000DB variant) which should provide more than enough power.
Do you guys think I should order new tweeters for them?
More like look for. They don't make them anymore, but they aren't too hard to find in the wild. You might try starting a WTB thread in Barter Town. I just sold a spare that I had yesterday. There was a pair on that auction site a couple of days back. They might still be there. I can't link it here because it's against the rules.
Well, one of the woofers stoped putting out sound today :( I think I have a wonky pair, so I posted it on craigslist for $75 for a loss, since its in remarkable condition. I don't want to spend more money or time on this anymore. Thanks everyone for your help
sorry you have given up. The problem with the woofer might be as simple as a broken or fallen off wire to the woofer, crossover or a solder joint in the crossover. Relatively simple to address if you want to, but as you indicate, time is money and neither is working for you. Have the next owner pop up here and see if we can't help him troubleshoot the problems. Nice of you to pass them on for a good price though.
I was hoping for a diagnostic. My bet was on a leaky seal somewhere.
If you don't have the time or inclination, moving them on is the right choice. Best of luck.
