Help: Phillips GA-312 Intermitent start issues
JohnnyBoy743
Hello everyone! I have a GA-312 for about 3 years now, yesterday it started showing a weird issue, when i select the rotation, it won't start by itself, but if i give it a gentle push, it starts moving. Note that it doesn't occur everytime, sometimes it spins normally when prompted, without needing a push.
Rotation speeds seems fine, another functions like stop and autostop works fine too.
Someone have a clue on how to solve?
here is a video showing the issue: imgur.com/a/ga312-AQ2l5rX
Start with replacing the belt! OR
try turning the belt over so the motor spindle is contacting a new surface. Good chance the side being used is glazed front age and use.
Either way its time for a new belt
motor shaft had a bit of gunk, cleaned it and turned belt over, if it solves i will order a new belt, thanks!
