Help Pioneer SX 780 stopped working
M_aurelius
My pioneer SX 780 has stopped working. I suspect the thunder and lightining happening a few days earlier might be responsible. Only the display lights come up nothing now and nothing else sound wise. No source lights. Thanks for your help.
Update: I have also checked all the 5 fuses behind nothing seems burnt.
I have the opposite problem none of the lights work but everything else does including signal strength meter. It's a Realistic sta 64b all three fuses look
fine to me.... Any pointers would be appreciated
Thanks
There are four fuses in there; Two at 1A, One at 2A and one at 4A. See fuse assembly AWR-169
Looks like a fifth fuse underneath? ~Dave~
You should comb through the threads in Pioneer; you will probably find more than one where this problem has been diagnosed and even repaired.
~Dave~
