FabGadget
I have a (so far as I am aware) previously-unused Pioneer T-6600 I just acquired that is having trouble keeping tape in the tape path, even after replacing all the belts. At first I could not get it to play/FF (it's an auto-reverse deck, so there's no rewind distinct from FF) at all for more than a second before the feeder reel starts spewing tape; and no matter which direction I had it playing/FFing, the uptake reel seemed like it was slower than the other reel. I put a drop of synthetic oil in the spindle shafts, the capstan shaft, and the pinch roller shaft as indicated in the manual. I did a lot of fiddling with the pads, and it seems like it's now consistently able to successfully play in the regular left-to-right direction with sound, but FF is only working occasionally without the tape slacking at the feed end. The reverse direction is still not able to play at all without immediately slacking.
Probably related to that, the left hub in particular seems to struggle the most to spin. At first it almost wouldn't spin at all, even without a reel. Without a reel, it's spinning now (mostly), but the lower pad that engages during playback is constantly making it spin rough and noisily, unless I manually disengage the pad, at which point the hub spins smooth and quiet (I can't tell if the right hub maybe is suffering from this as well, but it's not noticeable if it is). I find that the pad seems to be completely solid, which I doubt is supposed to be the case, to the point that I can't tell if it's rubber or dense felt that's somehow solidified with age. I can also feel the pad slightly sticking initially when I manually disengage it while the hub is stationary (though I'm not sure if it's the pad itself that's sticking or if it's the pad's arm as it rotates away from the hub).
All of that said, I hope it's not a situation where I'm fixating on the hubs/pads without that being the actual problem (or at least not the only problem), and what if it's not (or not just) that the uptake reel is too slow but that the capstan/pinch roller is too slow? I do notice the capstan flywheel is a little wobbly during playback/FF (though the capstan itself doesn't appear wobbly), and it has struggled with bumping into the speed-selector post, especially when the deck is horizontal. Anyone know how to get everything running smoothly?
