Jerry Hawtho
New to solid state, use to tube radios.
Problems
1 flunked the dim bulb test. Replace rectifier and two input caps.
2 left channel has +24v at speaker output.
Removed 2 output transistors. No help.
3. TR23,noted to have a broken lead (2SC1845). Removed
Voltages on "socket " -38B, -38E, +37C.
4. R161 2.2K off TR23 Smoked and open, + 34V on one side and--34 on the other!
5. C163, 33mfd shows +34v on both sides.
Other than trying to find the resistor and Tr23, where should I go from here?
Thanks for any help.
Jerry
Problems
Jerry
