marsupilami
Hello,
I have a Telefunken Opus 2430 EL95 push-pull amp from the 60s, it works great with no hum but as a preventative measure I'd like to replace the input caps. These are the only electrolytics that I could spot besides the two other 100 uf caps by the output (coupling caps?), and those have been replaced already by 150 uf caps.
I'm fairly handy with a soldering iron but don't have much knowledge in electronics so before I get started I'd appreciate it if someone could tell me that I'm doing things right (or otherwise heading for disaster).
First here's a photo of the capacitors housing and connectors :
Next here's what's written on the side of the housing (part of it is hidden from the rest of the chassis) :
Elyt 4x100 uf
350/385 V - ...
Minuspol - Gehäu...
-20 + 70 C
638
[] Auss. C. ([] being a square symbol)
And finally here's the link to the schematics :
http://soundup.ru/images/stories/library/schem/telefunken/telefunken-18/opus-2430.jpg
Now if I understand correctly inside the housing are 4 identical 100 uf electrolytic caps rated for 350/385V, the + end of each being one of the terminals with a little symbol and the - end being connected directly to the housing, itself connected to the chassis. From there my plan is to buy 4 100 uf / 400V panasonic electrolytic caps (I know, not ideal, but any other type of cap is huge and very expensive for those values) and simply disconnect the wires going to each terminal of the housing and connect it to the + end of the corresponding cap the same way, with all the caps' - ends connected together to where the casing is connected to the chassis. Is that the right way to do it or did I miss something?
Thank you in advance for your help, I really appreciate it!
Elyt 4x100 uf
350/385 V - ...
Minuspol - Gehäu...
-20 + 70 C
638
