Hello,
I'm posting this here because although it's my speaker that is going out, I think the issue is being caused by the pre amp or receiver.
This is my first set up and as such I'm fairly certain I'm making some sort of basic rookie mistake. My set up is as follows:
Sanyo TP 1020 tt > Art DJ Pre III pre amp > Denon DRA 365R receiver > Klipsch RP 400M speakers
So, initially, when I tried to use the turntable, as soon as the needle hit the record, the speakers would make a 'pop' sound and then not play anything. Through some online help, I was able to figure out that my mistake was having the pre amp plugged into the phono input on the receiver when I should have had the turntable plugged directly into the receiver and (optionally it seems?) the pre amp plugged into a different (CD or video) input. So I made that adjustment and it seemed like everything was working great. However, now I can play a record for about 5 minutes at most until the speakers make the same 'pop' sound as before and then shut down. At that point the record just plays off the turntable. I am able to listen to the radio continuously from my receiver without the speakers popping and shutting off so I don't think the issue is with the receiver and speaker wiring.
I've been piecing together this set up over time and am super excited to finally get it up and running so any help would be greatly appreciated. I'm hoping it's just a minor adjustment that needs to be made. Thank you everyone!!
