The point I am making is you can't really tell its not stereo. Your not sitting in a dedicated seat with the correct spacing for two speakers to be of equal distance. With speakers all over you get a stadium or concert hall type of effect.
How much of the time will their be a DJ? Do you want to invest in two systems? Because most every restaurant out their has a sound system. We put limiters on the VC control because as much as some of the staff might want to turn it up, most of the time the customers are saying, could you turn it down, we can't talk over the music. So if you go with a typical DJ set up with two PA speakers on stands or bins with arrays, your going to have some loud music up front and in the back of the house depending on how much you crank the VC it might not be to loud. A properly set up distributed sound system the sound levels are pretty even thought an establishment. VC controls are under the control of specific people either by limited access, (keyed VC controls), or the VC controls and other controls are locked in a cabinet or the managers office. Or you can have a laptop device or tablet which controls the functions of music sources, and VC controls.
A good system would be more versatile and work for both applications. If you wanted you could still use a additional PA system for with you have special events, simply add your front PA speakers or bins amps and such, and then have a receptacle in the area where you plug in the system to use with the regular sound system, its just another source that you can dedicate to your processor.
