Awesomeaudio
I have this 5 disc carousel cd player and it has a couple of issues.
It does power on ok and although the opening and closing of the draw has improved from what was initially not great.
The draw has an intermittent issue with opening on command. Sometimes it will take several attempts and finally decides to open. I opened it up to check for dry grease or other obstacles and found none.
Second issue is the carousel doesn't rotate. I can put a cd in any spot and it just doesn't respond even when I press the various disc number.
Anyone ever had a similar issue ?
