Mark Daniel
I picked up a Realistic 31-2020A EQ and the sound is great hooked into my Realistic STA-2080. Everything works as it should, except the spectrum analyzer which will display fine but only at very high level input. The EQ is hooked to the pre-amp out and then into the power amp. I check IC301 and C311 they are good. The slider pot VR301 measures 0 to 49.7k. What level should the display start showing up? I read that Q505 can cause the display to stay on all the time, but it too checks out. Any ideals?
