Help - Technics CD Player stuck
davespace8
Hello,
I have a Technics CD Player SL-PG340 that I bought new 25+ years ago. I used to play many CDs years ago, but for the past 3-4 years I didn't use it.
Now, it still "works". It reads all my CDs, all button works as they should, all is good until I press the eject button. If there's no CD inside, the CD tray comes out when I press the eject button. However, if there's a CD inside, the tray gets jammed.
I've removed the top cover of the CD player and the one from the actual optical unit (the metal shield that's above the CD). Without the top cover on, when I press the eject button, the CD is lowered with the metal shield, but the tray stays closed. During this time you can hear the mechanics doing something within the unit until it stops and the CD is raised again.
I found out that the CD gets stuck on that rubber ring (clamp?) below the metal shield. I've unscrewed the 3 screws from the metal shield and I've managed to peel the CD off of that part. Now, I'm not sure how it's supposed to be, but that rubber is no longer like normal rubber material. Now it's sticky and the CD stays there glued.
Everything else seems fine, the belt is still there and looks fine, the rails are clean and lubricated, and the laser is clean and works perfectly.
Has anyone got any ideas what might be the problem and how I can fix it if possible? Any insight/help would be appreciated!
Many thanks,
Dave
