I have a Thorens TD 125 mkII with SME 3009 imp. Fitted with Shure m97.
When playing at normal levels no problems. But when I crank up the volume, there is a acoustic feed back.
I have tested the following:
- I shut down the player so it stops spinning. When I place the needle on the record some place. The feedback comes when I turn up the volume to approx 90-100%. Below this volume. No problem.
- If I lift the cartridge the FB dissappear.
So apparently this is not a hum problem. And not related to vibration from spindle or motor.
If I pull the mains plug to the TD125 the problem is very reduced but not completely gone.
Help appriciated. Thx. Soren from Denmark. Amp NAD M33
