Hi, I recently bought an all tube guitar amp, except with a solid state spring reverb driver. It is a very well taken care of U.S. designed and built around 2005-2010ish CRATE V16 PALOMINO 1-12" COMBO AMP. Schematic > https://elektrotanya.com/PREVIEWS/63463243/23432455/egyeb/crate_palomino_v16.pdf_1.png
The problem I am having is since I briefly, as in a few seconds tried to attach a different, known working, for-solid-state longer (by a couple inches) reverb tank to the Palomino's IN/OUT Jacks it made a brief crackle sound and no reverb function, so I immediately detached it.
Upon reattaching the original spring tank the REVERB LEVEL ADJUST POTENTIOMETER DOESN'T FULLY SILENCE THE REVERB WHEN IT IS TURNED DOWN...it still sounds the reverb about 50% of full reverb. Not only this, but the reverb knob at full clockwise max is much more intense, "goes to 15". It's almost as if everything shifted , min 0 now=5 and max 10 now=15.
Note- The potentiometer itself has no problems
Both channels of the TL072 opamp do have output, and no diodes,resistors or capacitors around the entire reverb driver circuit have failed according to my DVM.
I did experiment adding 700ohms to 1k FROM TERMINAL ONE on the REVERB POT (P6) to GROUND. The results do lower the minimum setting, quieting the reverb level, but it comes at the cost of lowering the max level to around 6-7. I'm looking for a better solution.
Any help with this is very much appreciated, - Paul
