wlzed279
Hello All, I have been pulling out what is left of my hair trying to track down an annoying 60 cycle hum in my newly recapped system. I created an earlier post about this issue that I thought was solved but it is not. I have leaned on the community before and you all have helped me out considerably. I am hoping you can pull me down off the ledge on this one.Below are the stats and symptoms:
KLH Model Twenty System
Fully recapped including the power supply board and filter capacitors
Symptoms:
faint 60hz hum on all inputs in both channels
Can be heard with the volume turned all the way down
Not controlled by the volume control. If I play music, the signal will drown out the hum.
Weird symptoms:
If I wave my hand over the control board, the hum gets louder...almost like an additional hum added to the original. This will go away if I touch any part of the chassis.
If I move the chassis ground wire on either the power board or the left channel power amp board, the hum will change in amplitude????
What I have looked at already with no results:
Reversed the two prong plug into the wall socket
Reflowed and inspected the chassis ground connections on all boards
Tried shorting the rca connection on the Aux input.
Tapped around all the ground connections to locate any loose connections.
I am completely stumped on this one. With these symptoms, should I focus on the Power Supply board since it appears on both channels and is not controlled by volume. Where on the power supply should I check for AC that should not be there? Is it possible that the rectifier diodes are leaky? How would I check those? I am pretty sure the new caps are in using the correct polarity.
Since I recapped this system it sounds absolutely amazing. It is just this low level hum that is driving me crazy.
Thanks as alway for your assistance.
Symptoms:
Weird symptoms:
