navidmustafa
Hello Experts, I have a question regarding the replacement of transistors in my AudioAnalyse A9 amplifier (Pure Class A, 50WPC). This amp delivers excellent sound quality, which I really enjoy (sweet, calm, with a wide soundstage). Unfortunately, two MJ15015 transistors have shorted, and after reviewing the schematic, my technician friend raised a few concerns and suggestions. I would appreciate your expert opinion on the following:
(Schematic attached)
- Why are the same transistors (MJ15015/MJ15016) used both in the output and driver stages?
- Can we replace the MJ15015/MJ15016 transistors with MJ21193/MJ21194 across the board?
- Considering the different HFE values (20 vs. 75) and Ft ratings (1MHz vs. 4MHz), would this be an upgrade or potentially cause issues?
- If MJ21193/MJ21194 can be used in the output stage, should the driver stage transistors also be replaced?
- Or should we stay with the original value transistors?
