Lewis Biggs
Last night, I successfully (to a certain point) recapped my 2216. It sounded good, but I could not leave well enough alone. I decided to check/adjust the voltage across resistors R735 and R735 per the manual. I got a little careless with the probe (easy to do) and, while the unit was powered on, grounded the leg of R735 that connects to C721.
The left speaker immediately popped and began to hiss. Although music will play out of both channels at normal volume, the left channel sounds mildly degraded and hisses. Changing the volume does not affect the hiss at all.
When I switched R and L from the preamp board, the hiss stayed on the left channel and is unaffected. Thus, I believe the problem to be limited to the L side of the main amp board. I do not see any visibly cooked/bulged components, and I was not able to find any obviously bad components using a multimeter. In comparing ohm readings between transistors on the right and those on the left, some of the the readings are substantially different, leading me to think that I cooked one or more transistors.
Any ideas what I have done? Any tips for troubleshooting without a scope or is any further hackery by me just a waste of time? I would be very grateful for any advice.
