Hi All, humbly asking for help as I'm at the end of my rope with this. Hope I don't get crapped on here.
I have adopted a one-source policy for my systems. I like having my entire prodigious music collection in high resolution lossless digital format, so I run a Cambridge Azur 851N with my vintage equipment.
I have been using Carver gear. Before I get pilloried bear in mind my ears kinda love Bob's stuff. I can't help it. Before someone says I don't know what musicality is bear in mind I have been an actual musician since I was eleven and I read music and play several instruments. So I know what music is at least. Musicality? I guess that's up to whoever wants to throw crap at me for being a fan of Carver gear (only the Bob era gear, not the post-Bob era gear).
Recently I had a beautiful Hafler 945 pre/9270 power amp combo serviced by Rolland Barr. He is a good guy and I've had Carver gear restored by him and have been satisfied. Folks the Hafler gear hates the network player. This equipment has no XLR inputs so I am using the unbalanced outputs of the 851N to connect to the Hafler gear, into the CD input of the 945 preamplifier. I am using six-braid interconnects from Pine Tree Audio.
I can clearly hear what I presume is the central processing unit or the internal data bus of the 851N processing data when I play a track from the USB flash drive inserted into the rear of the unit. As I listen to the noise, I observe it is synchronous with the small light blinking on the USB flash drive.
I get the same noise when changing internet radio stations for example, and once the music begins to play the noise is greatly diminished but not entirely absent.
Whenever the unit has to 'think' it makes noise. So- I believe that the data being processed inside the 851N is the source of the noise.
Now I can experiment further by separating the components by proximity. I have some cheap Monoprice interconnects that would allow me to place them in separate rooms. Also Rolland advised me to get some 3 to 2 plug adapters to rule out a ground loop issue. Carver is lamp cord-tastical, Hafler uses three prong IEC.
I should say I'm not just plugging the gear into the wall socket, they go into a Furman Elite 15i line filter.
Just curious if anyone has any thoughts about this. That Hafler gear has a different presentation than the Carver gear and I really love it. Still love my Bob gear but the linearity of the Hafler is remarkable. I'd like to keep it in my house and not sell it off in frustration. Because, well I bought another pristine 9270 so I can run two in bridged mono for 400W @ 8
Thanks
Thanks
