Help! Why does my system sound so bad?
jonklaus
OK -- I'm a total newb, so please be gentle in your replies if I say something stupid.
My system sounds awful, and I don't know why. I have equipment that people tell me should be pretty respectable, and others have said that the speakers and receiver should be nicely matched. But the result I get is harsh, brash, overdriven. I can only turn the stereo's volume knob up to "1" or between "1" and "2" before it's too loud to be pleasant in a fairly large living room with high ceilings; higher than that and it's downright grotesque.
Here are the specs on the setup:
Receiver: Kenwood KR-2600
Speakers: RTR Exp-8v
I don't have the specs on the CD unit or LP player that I've got, but the system sounds pretty bad with the radio on, so I don't think that those items are the problem.
Any advice? I'm assuming that I need a pre-amp or equalizer. But what, and from where?
Thanks!
Jonathan
I can't tell you but I would borrow another pair of speakers and see if it sounds better, or take your speakers to a friend's and try them there. Process of elimination works best for dummies like me. I have a lot of stuff laying around so it's easy.
Good luck!
Don't know the specs on your speakers , but the KR2600 is only 15 watts per channel, so it could be possible that if your speakers are very inefficient you're experiencing clipping by turning up the volume on your receiver to get it to a level that your happy with. I would suggest trying the speakers with a more powerful receiver/amp, at least 40-50 watts and see if you have a better outcome.
Here are two awesome threads to check the health of and clean your receiver.
The idiots guide to using DeOxit.
Amplifier Dc offset and you.
Having trouble transfering the links but they are a must read if your system sounds that bad. As others have suggested process of ellimination is key but these are the first places I would start.
Next swap out cables. Found one in my system causing issues.
Interesting speakers if they look like the pics I found on the internet.
Are the ceilings vaulted? ... if so that could be effecting the sound.
A home I used to own in Colorado Springs Co had vaulted ceilings and my upstairs stereo never sounded right to my ears.
My basement stereo back then sounded better.
?! You can barely open the volume and you are getting overdriven signal level from your speaker? Did you connect your CD player to the phono input by accident?
Check and make sure you have the polarity correct on your speaker wires. Simple thing to overlook and makes a big difference in sound quality.
Along with all the good suggestions here, I'll add that it may be insufficient bias on the active devices. Other than that, I would look into room acoustics absorption panels and possibly investigate the source, ie catridge, stylus, DAC, and so forth.
Thanks!
Jonathan
Some photos of everything front and back and the room would help.
I can't find the specs on your speakers, do you know what they are?
Do you have the speaker wires connected R to R and B to B??
Most amps run out of juice at 1-2 o'clock, leaving the rest of the control for low level inputs. With a CD player that Kenwood should start to sound bad and stop going up in volume before 1:00. If this is true and the volume is not loud enough for the big room, you need more power.
Usually a 15wpc solid state electronics and regular speakers are for smaller rooms or lower listening levels. How loud do you want to listen?
Thats what im thinking too Shadow,but does he really mean 1-2 (o'clock) or just 1-2 on the dial? If o'clock yeah,if on dial,he has problems!
Good point.If the system should sound good to some degree and doesn't probably means there is another problem. One time I had a Sansui 9090db and a pair of kabuki Sansui Z-99.This was a few years ago when good volume without distortion was what I was looking for.Sounded pretty good airing this stereo out in a room with carpet and drapes.Moved it downstairs to a tile floor and it sounded terrible.
Maybe the speakers are out of phase and the bass is all the way up and the loudness is on.
Seems like we have covered all bases and it is up to the OP to report back some of his attempts to make his rig sound better.
2nd the ''ditch the kenwood-'' did I mention ''ditch the kenwood;''? ok last suggestion...ditch the kenwood.
let's no morph.. wait for OP. dimensions of room etc. are all important. (plus his budget)
NIce to see so many contributors.. must be audio mating season. :D
