Someone else recently posted asking about the Sansui 2050c, so I've copied my response with a few edits:
I owned a Sansui 2050c for about a year before I lost it in a fire.
It was a very nice turntable! I think what I liked about it most was its elegant simplicity. It's a semi auto (auto lift, no return) that benefits from having very few moving parts on the inside of the table. There is very little break or wear out.
I also thought it looked pretty handsome. Real wood cabinet, suspended metal plinth, and a classic S-arm.
I only had one complaint: when the auto lift engages, it is typical for these tables to make a pretty loud TWANG! sound as the cue lever slams back into its original position. On the bright side, you will definitely know when your record has finished playing!
Also, make sure it comes with the anti-skate weight. Replacements are impossible to find.
Sonically, you can do better, but I thought it was a very decent turntable with a lot of character. Good luck on your quest, and choose what makes you happy!
