Oh my....
THAT is the evidence of some HACK that repaired (or tried to) that board before.
I could clean that up very well, but that's really bad.
I thought it had been tinkered with before. But previous tinkering aside, is that joint the culprit?
It well could be, did you probe each side of that damaged area with your meter set on OHMS to see if you even had continuity there?
Casey
The glue on the cap could be remnants from prior tinkering. That cap on my board was mounted on the top side and had a vinyl tube sleeve over it, I'm guessing to help shield it from heat. When I removed the vinyl sleeve, the inside of the tube and the outside of the cap has this glue on it. So I guess it is possible the cap was either on the top side or had a vinyl sleeve over it at one point in time.
The copper traces on your board under TR-01 appear to of been worked on in the past. This is the typical failure area on this board. It is possible that the pad (the circular area where the leg of a transistor, resistor, diode, etc. solders to) has lifted from the circuit board wafer material. If so, you will have to make a significant repair to the board. I would also check the continuity to the next component in the circuit. If the traces are intact then reflow should work. If not, the you will have to recreate the trace with wire.
It looks like some of the varnish was scraped away to either get a clean surface to solder to or to get a clean point to check with a meter probe
Good luck. You can refer to a picture I posted earlier in another thread for the repair that I had to make, which appears similar to the repair you may have to make. I would caution that if the board does need an overhaul, it may not be do-it-yourselfer depending on how well you understand schematics.
That looks basically correct. You should still pick-up the heatsink in the circuit. I've included a pic of my repair that worked just fine. I have to admit, the photo has one error. I soldered one of the wires to the wrong pad. I marked the correct location on the picture. Luckily, I caught the error before I powered up the board.
On my board, all 3 of the pads for TR-01, as well as the heat sink mounts were shot. Since this area gets very hot, I elected to run wire for all 3 legs of TR-01 and be done with it.
You could read thru this thread, you might find some info useful http://www.audiokarma.org/forums/showthread.php?t=198087[/QUOTE
Thanks for the pics, unfortunately your power board looks different than mine. I did read the thread. Nice neat job. Where did you get those nice terminals on your wires? I was following this schematic posted by CDFixer. http://www.audiokarma.org/forums/attachment.php?attachmentid=52134&d=1182225389
After looking at that board diagram and at your board, I think the board diagram is more like my board than yours. I think yours is a newer version that is not completely reflected in the diagram . If you notice, I have a connector on my board for the black wire to connct to (near a screw). I did not see this on your board. However, that location is shown on the diagram. Also, next to the variable resistor, there are 2 fixed resistors (R-05 and R-06), the diagram looks more like my earlier board. Looking them over though, you can see they are basically the same. R-01 and R-02 are the resistors that can be relocated and combined.
Here is a pic of the actual schematic of the board in circuit if it helps any
http://www.audiokarma.org/forums/attachment.php?attachmentid=124112&d=1229656116
As I mentioned earlier, my cap is on the top side of the board. Sansui later re-positioned the cap to the bottom of the board to get it away from the heat.
The bridge you propose should work just fine. I connected my heat sink to the other resistor (R-01 and R-02 are parallel). On my board, the trace from the center lead of TR-01 was also shot so I connected it to the resistor that you point to in your picture. Both connections are the same since the resistors are in parallel. This way, I didn't have to try to get 2 wires soldered into one joint, I split them up.
Connecting a wire from your heatsink mount to either R-01 or R-02 is the same. If you look at the trace, it is common to one end of both resistors.
