Doctor3165
Hello, Wanted to see if I could get an opinion or two. I acquired this unit several months ago. It was aesthetically super clean but had the typical scratchy noise when adjusting volume. Took it into a very reputable tech and he cleaned all controls, replaced power amp caps and about another dozen caps based on a full look over. (He did several other minor things as well).
The reciever is fully functioning and sounds fine, independently. I am running it through a pair of ADS L810's. I also ran it through a pair of Genesis 33's.
Here my question. There seems to be a flatness to the sound. Not dynamic. When compared head to head with my Pioneer SX880 it comes up short. Well short. The imaging and lower and upper ends did improve when playing through the Genesis but still not even close to what I was expecting.
Assuming the Sansui is working as it should, is this possible? If there was something that could cause this, what may it be?
I want to be prepared before I take it back into the shop..
Thank you!
Thank you!
