Help with a Realistic LAB-500
Bucky Badger
AK Subscriber
Hey Guys and Gals, I found a nice looking Realistic LAB-500 TT sittin' next to a garbage can and wanted to bring it back to it's former glory. The headshell was broken in half and it looks like it might have a little speed issue. I have a headshell that resembles the original and a Shure V15 IV I can stick on it but wonder if there is a way to lube the motor and clean any switches? Can't find an owners manual on line...... Any help is appreciated.
BTW, There seems to be quite a bit of info for the LAB-400. I kinda thought that the 500 was a step up from the 400 but with the lack of info I'm wondering if this is a well thought of table and worth restoring. Seems heavy enough and well made. CEC? Technics?
CEC-made, I believe. I have a spare one here that works fine. Your should be able to clean the switches using a can of DeoxIT... same as you'd do with any other dirty switches. I can't help with the motor lubrication question.
Check page #20 here. The LAB-400 and LAB-500 were available at the same time with the LAB-500 being the higher priced model. The principal difference is that the 500 was quartz locked.
It may have been made by someone else too. Most of the good Realistic tables were made by C.E.C. but thias doesn't look particularly C.E.C.-ish. In fact, it looks Mitsubishi-ish, a virtual dead ringer for a DP-86DA
John
CEC probably made the Mitsubishi, too. They made turntables for lots of companies, often times with no more difference than moving a few buttons or other controls.
That's certainly possible. Mitsubishi made quite a few of their own tables but C.E.C. made turntables on occasion for companies that at other times made their own. The thing that makes me tend toward thinking that Mistubishi made the LAB-500 is the gimbals. It really doesn't look to me like those that C.E.C. typically made.
John
John
The 400 and 260 are definitely CEC products (the 260 has a whole lot in common with the Craig 3000 series table, a real sleeper). The 500 doesn't look at all like CEC's work.
