Lovemystereo
My tube amps are installed in a cabinet and run hot after a while operating. Not an option to have outside the cabinet. To solve this after some research I purchased and installed a 120mm 115 volt ac (direct plug in fan – see link below). Recommendation I read was to go with AC rather than low voltage DC (wall wart plug in type) to minimize interference. There were a number of control options, such as variable speed. Taking the automatic hands off approach I opted for a unit with a thermal switch incorporated (On at 85 degrees, Off at 75 degrees). It works to cool, though louder than I would like.
The problem: when the fan operates there is a loud clicking sound from the speakers. This is ac line interference, I am certain. Not come across this issue before. When fan is NOT operating, everything is great, but the moment the fan starts, so does the noise, making the fan unusable as a cooling device due to the interference.
Here is link to the fan I installed- https://www.productsforautomation.com/gardtec-gcab702-120mm-120V-cooling-fan-kit-p/gcab702.htm
Any ideas on solutions appreciated? Seems like in trying to solve one problem, I have created another! Hopefully there is some kind of ac filtration or something I can install between the fan’s plug and the rest of the system to shield/filter out the noise? Or some other way to resolve?? The main amp is plugged directly into the wall, while all the other components including the fan are plugged into a UPS incorporating surge protection.
Thank you in advance for your assistance.
