durk80
Member
I have a Sony ICF9740W table top radio. The AM reception is decent at night time; however, I would like to add in a jack to plug in an antenna like this:
I've packed the ferrite rods in the pvc pipe, wrapped the coils around the pipe, and attached the variable capacitor to the primary coil. I haven't laid on the coupling coil yet. Within the radio, there are four thin leads I can see from the built in ferrite antenna that go to the circuit board. I'm a little lost with where to solder in some shielded wire to add an external antenna.
