Sam Hopkins
Hello everyone,
I recently purchased a Bogen DB10 tube amp which looks like it's been taken very good care of and rebuilt at some point. According to the manual, in order to run a turntable through the high or low mag inputs, a cable must be connected from the pre-amp out to the amp input. When I do this and run the TT through either high or low mag inputs (I'm using a Stanton 500 V3 cartridge), I start getting a fast clipping sound when the volume is increased only at about 20 percent. When I back the volume off to just right below the point it starts clipping, if I then increase the treble it will also start making this same sound when it gets to a certain point. It used to give me a slower chirping sound when I first got it but now it is a long steady but fast clipping noise. The patch cable I'm using between the pre-amp out and amp input is brand new and tested.
If I plug a receiver straight into the 1/4" amp input bypassing the pre-amp stage, it plays clear and very loud. If I plug my turntable the same way directly into the amp input it also sounds fine, but of course the volume is very low even turned up to maximum without the pre-amp.
Any clues what the problem might be? Supposedly the tubes were all tested. I have very limited experience in electronic repair so please bear with me.
Thanks in advance for any advice!
