bigx5murf
I'm at wit's end with this humming issue on my CS 508, with 1/2' adapter. I have a bad hum in the right channel, the hum will come and go if I disconnect the right channel rca and move it around. Doing so will also make the left channel cut in and out and hum at times. The ground cable is connected, it'll hum much worse if I disconnect it.
I've deoxit the 1/2' adapter, and the springs connectors on the ULM headshell. Crimped the cartridge cables to make sure connection is tight.
Am I looking at RCA replacement?
