Hi Sansui experts! I purchased this G-9000DB knowing it was stuck in protection mode and blown right channel. After a month of replacing the trim pots,many blown resistors,transistors and all of the small e-caps.I didn't recap the oval caps yet.I also did clean all the switches and potentiometers 3-4 times each.I was able to bring it back to life again. But I still have the problem with the crackling sound on the right channel. I did switch the driver boards from right to left but the crackling sound is still with the right channel. Then I disconnected the connection switch and use the G-9000DB as preamp and my AU-717 as power amp then everything is fine. Then when I use the G-9000DB as power amp and the AU-717 as preamp then I can hear the crackling sound on the right channel again. I hope Sansui experts can guide me to find this annoying issue. I'll appreciate all of your help.
