Hi folks, first post here, hoping someone can help me with my 299B. I'm a little rusty in the tube department, my first training was in 1971 and that quickly moved on to transistors and IC's. I have had a wonderful (partially restored) 299B for about 12 years now and recently it got a bit scratchy sounding and one channel is a bit muddled/distorted. I dragged my Hickok 800 out of the attic and all the tubes tested good. I shot the rotary switches and pots with deox and that cleaned up the scratchiness. The B channel is still a bit reduced in volume and muddled. I shook the rust off my VTVM and checked the power supply voltages (all good) and then moved front to back checking plate voltages. On the A side (good side) all plate voltages checked good. On the B side (muddled side) all the plate voltages checked good except for the final push pull side of the 7189's. Bottom 7189 plate (and primary of the output transformer) reads 420V as it should, center tap of output transformer reads 430V as it should. The top 7189 plate and other primary tap of the output transformer reads 0V. So maybe I'm getting push but no pull? I unplugged the unit, removed the tubes. Resistance check of the primary side of the output transformer reads infinate ohms (almost like a cap would read, pops down then goes to infinate ohms) top tap-centertap-bottom tap. My A side output transformer primary reads 200 ohms from top and bottom to center. I'm thinking the output transformer is toast.
Do I have this right?
Any other checks I should do?
Suggestions on where to find a replacement?
thanks for any help!
