lorne
Sonic Lizard
I have a problem with the simplest thing — and it is driving me bonkers:
CONTEXT: I decided to replace the switch in the step transformer that I boxed and wired a few years ago. I replaced the rocker switch (off/on) with an illuminated one.
The NEW switch has an illuminated rocker. Rated 125 VAC, 8 Amps. This is a Japanese switch, and so it is intended to work on our 100 VAC mains. It has three blades — 1, 2, 3. I've wired 1 on the wire to the fuse. 2 is wired on the other side of the switch. 3 goes to ground (transformer frame and chassis). But, NO LIGHT on power up. The switch itself tests fine. And I jumpered another illuminated switch into the circuit and still no light.
Please help save my brain from frying!
