gkwolfman
USAF 1973-1980
In hindsight, I inadvertently dialed R507 & R508 adjust pots during my amp check up (the idle current & bias). So, I am needing to reset the power meters.
I have a question about the resistors? (507-508), I have them turned counterclockwise to do the reset, but as of now I don't have the dummy load and a signal source.
My question is, can I use my amp in this position without damaging the amp until I have the tools to do the power meter adjustments? Surely R507 & R508 have nothing to do with the wpc output of the amp?
I may try and download a signal/or/use a signal (sine wave 1kHz) from my desktop to my aux and does my 8-ohm dummy load need to be a measurable wpc (ie. 100 wpc)??
