Hi to everyone from across the pond. I need a bit of assistance with an A76 from you learned ones. I was given a couple of pieces and this A 76 is one of them. I hooked it up with speakers, turntable and tape deck, phone . Tried them seperately but no sound unless I turn the volume up full and can just about hear the music. This is the same for the headphone socket. The tuner/cd/phono/aux light up on the display but all rca sockets on the back on the back appear to have no sound. There are a lot of connections on the back which I dont really know what they are. I wonder if this was a part of a stack system and needs a graphic equaliser? Is there a mute button that I have missed? I thought that I could just try it as a stand alone amp. Any help would be greatfully received. TIA
Update: Thank you you all so much for your invaluable advice and guidance. You really are stars. I have got the amp working, albeit no remote. It sounds very good. I used two old rca leads that I found. The back is awash with wires. Needs tidying up. Respect to you all. Thank you again
