Thank you for the information. It is indeed the power switch as the problem goes away when I hard jumper across the contacts.
I have been able to locate three switches NOS ("new old stock") and have ordered all three. These are Kenwood original parts and should correct the problem (at least for a few years). Because I have three switches I should be able to keep the unit operating indefinitly. These were not easy to find and I doubt if any more are available anywhere.
However, I found this interesting link for others with the same problem:
http://www.number63.ca/kenwood/kenwood.htm
Thanks for all your help!
2 things:
1) I posted a diagram a few years back how to not only fix, but modify the switches to work forever....echowars helped me pdf it and it is here somewhere
here: http://www.audiokarma.org/forums/showthread.php?t=105429&highlight=kenwood+fix
Nice find. I made a pfd of that whole thing.
The only thing he forgot is a safety cap. As the contacts close and open, there is a time when they are close enough to arc. This will eventually destroy the contacts unless a safety cap is connected across the contacts to eliminate the arcing.
A safety cap is a specially designed cap, and specifically rated to be placed directly on the AC line. It's design is such that it will fail open, not shorted. Digikey sells 'em, Panasonic Type VS, 10,000pf (.01µf), PN. P11423CT-ND.
hi Tim, 5/2/2026I recently purchased a Kenwood KR-4070. It works great except when first turned on... it initially flickers (the lights go dim and bright repeatedly and intermittently) and the sound is garbled for several seconds to several minutes before stabilizing. The problem appears to get worse as the unit warms up and is power cycled.
I previously owned a KR-5030 that did exactly the same thing (never resolved). I see from several other posts that other owners of the KR-4070 have experienced a similar problem.
Does anyone know what is causing it and how it can be resolved?
Thanks --
Tim
