Lost Cause
So, I picked up a pair of Klipsch K77 tweeters, for a yet-to-be defined project. Price was right. Or, at least seemed so.I hooked up both tweeters to a small 15W amp, just to test 'em out. The volume from one was significantly louder than the other. The louder one seemed distorted a bit, too.
I ordered some replacement diaphragms from Simply Speakers to freshen them up.
Opened up the tweeters and, turns out, the gaskets were missing from both. So, I made up new ones with some very thin foam and a few tries with an X-Acto. Also, one of the voice coils was tight, seems the magnet was knocked and misaligned. Fixed that as well, which I thought would solve the main issue.
Once soldered in the new diagrams I buttoned them all back up. They both sounded much better, with the distortion gone. But one is still significantly less loud than the other one.
They measure resistance at 6.2 ohms and 6.3 ohms respectively, so should be spot-on.
Any ideas on what could be causing the issue and how to solve it? Obviously, I'm not an electronics expert and still new to this site, so please be gentile.
Thanks in advance!
