Gentlemen:
Hopefully someone can help me out here..I've searched the archives enough to make my eyes bleed....
Quick history: I've been lurking for a while as I continue my search for the perfect Mac amp combination for my Klipschorns. I began with the MA-6500, then traded up for the MC-252 paired with C-2200. But I couldn't stop thinking about how an all tube setup would sound. My dealer had a MK-275V on his floor and allowed me to audition it with my system and compare with the MC 252.
Wow! The light came on and I finally understood what the tube thing is all about. I think the MC 252 is fantastic, but the MC 275 with my speakers in a "bright" room was clearly a way better match. But the blue meters seduce me, so I picked up a MC 2102 from another dealer's showroom to audition. My original dealer graciously allowed me to borrow the MC 275 again so I could compare the two.
Here's my problem: the MC 2102 requires significantly more gain to achieve a similar volume level to the MC 275, if that makes sense. In other words, if I play the MC 275 at "30", to reach what seems to be the same volume on the MC 2102 requires level "35 to 37". I am using identical unbalanced cables on both amps, with the input selector on each amp set to "unbalanced". I am using the 8 ohm taps on both amps.
Has anyone else noticed this difference between these amps? The MC 2102 doesn't seem to be defective as far as the sound goes. Could tube burn-in be a factor? I was told that the MC 2102 had about 2 hours total time on it.
This is complicating my comparison of these amps. My first impression is that the MC 275 wins hands down in terms of presence and bass response, but this could also be the case if I'm hearing the MC 275 at higher volume, couldn't it?
My second question: Are the later production MC 2102s manufactured with fiber optic lighting? The meters have a pale, almost green "washed out" look when compared with my C2200 with the LED light kit installed by Audio Classics. If not, is an LED light kit mod available for the MC 2102? I hate to say it, but the disparity in meter lighting would be a deal breaker for me if I decide I prefer the sound of the MC 2102.
I'm out of most of you guys' league, except for maybe one thing..I've become obsessed with this quest.
Thanks for your patience .
Mike
Mike
