I'll look up the article, otherwise, you would have to ask mr Barbour...who knows what he's talking about in my book. Let me dig it up. I can tell you several built these and liked them, so there is something to it. Aparently that amount does not saturate them I guess. Of course you are only getting a watt or two at most.
russellc
That's pretty much it.
The original article was published in Glass Audio during the height of the revival of DHT amps in the US. At the time, everyone seemed to be going for 300Bs, 2A3s, 845s and the like. This could get expensive real fast. Barbour's logic behind the concept of Single Ended Glory... was low cost using what he believed to be mostly "junk box" parts and a good but low cost DHT (#45). Since decent but low cost SE opts weren't readily available, he proposed the use of a PP OPT in the 25-40 W class and originally designed for 6L6 or 7591 use. This got one a P-P impedance of 5-7K which would match up with the #45 nicely. Since the proposed #45 op pt is in the range of 35mA, Eric assumed that saturation woudn't be an issue with a 30 W PP opt running 2W of audio along with this. Based on numerous reports, apparently Eric was correct.
A major glitch with the SEG concept today is that the proposed PP OPTs came from things like Fisher 500s or Sansui 1000As...not particularly worthy of the term junkbox today IMO and certainly worth a lot more than $100/pair esp if on a restorable chassis.
FWIW, AA's amp appears to be an implementation of SEG.
