Help with Oracle PSU
guystp
Well-Known Member
Just my luck, first I break a cantilever on a newly rebuilt 103R, now the psu seems to have packed it in on my Oracle Delphi MK11. Tried all the connections, but alas...no juice! Does anyone know of a good source for new or good used psu's?:sigh:
The PSU will be labeled with its voltage output. Really any transformer with enough output amperage should work just fine.
Thanks for the responses everyone. Jacque from Oracle has very promptly responded to an email, and he's sending me a brand new replacement unit right away! Problem solved, I hope:)
The old Oracles suffered a bit of qc issue with regards to the regulator board...specifically the solder joints were cold and failed prematurely. These are a fairly simple fix - I was able to do mine while it was still on the deck. No parts needed replacement.
