Help with Pioneer Speakers
I think they are.I believe from a cs series and has the lights that light corresponding to the volume.Late 70s early 80s.If your more into rock I think $40 is ok but will probably need a refoam
yup, pioneer cs-903...I don't know about the quality, or the value...but I had a pair of cs-210gw's that were not too great (albeit, much further down the quality line)...maybe they are good speakers, but i'm not too shure:scratch2:, the whole cs line does not get many good mentions. I could be wrong, but I'd definitly do some research before jumping on it. I may be wrong, seems some people around here kinda like the upper-end (like this) of the cs line. I will admit, the built in tone control, and meter are very cool.
here's a link with a image of the speaker in much greater detail:
http://www.randallareed.com/photogallery/Pioneer%20CS_903.JPG
hope that helps...
Edit: the ones in the cl ad must be just a small step down from the cs-903's .though I have no idea how that series is numbered, you can tell because the cs-903's seem to have slightly larger mid-range drivers (relitive to the "horns" or "vents").
Double Edit: they are cs-803's...
