tdharmless
I recently restored and modded a TD 145. It has a hum or buzzing sound that is frustrating me. I've read through many of the other threads, none of the previously posted suggestions have fixed the problem.
Here's link to a video: PXL_20260130_231016621.TS.mp4
It's a noticable buzz, mostly from the tweeters, in both channels.
In the attached video, you can hear the buzzing sound. It's mainly noticable at higher listening volumes. So, it may have been present before the restoration and I didn't notice.
Here's what I know and have tried:
Edit: I tried to edit the title, but I can't. It should be "hum", not "him".
- Removed the ground from the right channel (—) and soldered a new ground connector to the back of the turntable.
- Separated the chassis ground and tonearm ground, attaching the tonearm ground to the new external connector and the chassis ground to the right channel (—), and vice versa.
- Replaced the RCA cables with new connectors on the back.
- Deoxit'd the headshell connectors and replaced the cartridge wires
- Swapped cartridges
- Test both channels and ground for shorts and continuity with a multimeter from the headshell to the RCA connectors.
- The sound remains when I hold the tonearm. So, it seems grounded.
- The sound remains when the turntable is unplugged. My previous turntable (Phillips AF 877), however, did not have this problem. So, I don't believe it's the amp (Denon PMA-1600NE) or power source.
- The sound does get louder if I touch the tonearm wires inside the base. That may be expected though.
