jgrandi7
I received a Technics SL-Q6 from eBay listed AS IS/BROKEN recently, when the only listed issue was a broken stylus. The tone arm was confirmed to work and the platter spun, so I figured it probably just needed a new cartridge/stylus. I bought it for $60, and the seller was nice enough to package the original cartridge, an AT152, which from what I've seen is a pretty good micro-line capable p-mount cartridge. It would take a while for a replacement stylus to arrive, so I have been using a cartridge I have on hand, an AT450LP, in the meantime.
The machine sounds great. Speed is spot on, the tone arm moves smoothly, and I'm really surprised how well it performs. My main problems are with the programming feature. When I press one of the numbered buttons, the led that's supposed to turn red flickers a bit, and I have had to push it a couple times for the led to stay on. The sensor will scan the record, but when it reaches the end, the led turns off, and the tone arm moves back to the start position, seemingly forgetting that it scanned in the first place. I have tried changing the sensitivity setting of the sensor to no avail. Each of the numbers has the same issue where it will light up briefly, and I will have to hold it for a few seconds to stick. Is this a problem I can fix, or something electronics related that would be impossible to fix without getting a new record player. I'm happy with it now, but it would be nice if the feature worked properly. Any help would be greatly appreciated.
