Hi all,
This project is about replacing a two-way configuration on old speaker cabinets for a four-way one.
To do this I had to cut new holes and I set up two tweeters, one mid 8" and one woofer 12".
Now I have to tune the bass reflex and finish the design. I don't know the parameters of the speakers, their coils were replaced also. The cabinets are already built. So, what I understand I need to do is go for the empirical way of tuning a bass reflex based on the resonance frequency measured on the woofer.
The dimensions of the interior of the cabinets are approximately 82cms x 43cms x 35cms (32" x 17" x 14").
There will be silly questions for someone who is into designing, sorry for that. That's why I'm here
These are the questions related to the design and the tuning:
1) The woofers' resonance frecuency is 37Hz, should I tune the cabinet for this frecuency or something close but up?
2) In the 8" mids, should their back be covered to avoid bass to interfere modulating the cone?
3) The absorbing material, should be placed on 5 sides of the cabinet (not the front) or should I ommit another one also?
4) Where is it more convinient to place the tuning tubes, down to one side or somewhere else?
5) About the diameter and lenght of the tube, knowing only the volume of the cabinet is there a way to get initial values without the speaker data?
6) How do I know if I should use one or two tubes?
Ay tips will on any of the questions will be greatly appreciated!
Thanks in advance.
Thanks in advance.
