lenos
I recently completed a ground up rebuild of an HF-81 using all new components except transformers, switches etc.
It took a bit of debugging to get it all going but then I had a few moments where I could hear what this thing might be capable of before other issues popped up.
One of the things I'm struggling with is hum.
From reading many other posts it seems that the general consensus is that most hum issues are a result of some sort of grounding issue. To be honest I didn't follow the directions exactly regarding grounding when I put this thing together, and so am revisiting that. In doing so it seems to me that the path to ground is somewhat circuitous in lots of places.
In looking at the intended wiring and schematic it looks like all the cathode resistors and cathode bypass capacitors eventually end up being grounded through what is referred to as Grounding Lug "G". I'm sure there is a logic to this (which I ignored). The thing that bothers me is that there are a lot of intermediate connections. An extreme example is for R43 which connects the cathode of V5A to ground. It connects from V5-8 to Terminal Board (TB) 7-1. From there the route is TB8-2, TB21-1, TB11-3 and then Grounding Lug "G". It would seem to be a lot simpler to connect a ground wire directly from TB7-1 to Ground Lug "G" and do the same for all the other intermediate ground connection points. I would plan on replacing Grounding Lug "G" with something having more room for connections.
Is there anything conceptually wrong with that?
My thought is that if I can get away with two soldered connections rather than eight (for this particular example) there is less potential for things to go sideways. Also, some of those terminals get mighty crowded when you stuff them with shields and multiple interconnect wires.
I recognize that grounding is a lot like voodoo but would like to hear other's thoughts.
Thanks.
Thanks.
