So, I've been burning it in since the restore to shake out any issues, and one did crop up. Every now and then a spike would come through the speakers, but I wasn't really thinking much of it since I've been playing a lot of albums and most have a bit of snap crackle and pop. Today was mainly radio at first on the T-526, and there it came again. So having recently looked again at the bad transistors list,I decided to dig back in again to the PS and the Main amp board, as I'd left a lot of originals in there if they tested OK. Found several different things installed as compared to the scat/component list. Ended up replacing all but one remaining 2SC733 on the PS board. It also still has the original outputs. One of the transistors (a driver) had a leg snap off, and another looked really tired. So far, no spikes! And Abbey Road on vinyl just sounded amazing.
Things that got replaced today:
PS Board
4 x 3A 100V rectifiers (real crusty legs from some corrosion) -- IN5404 (3A, 400V)
Q901 - SM says 2SC733, that was installed and stayed since it measured 500+ hFe and I only have the KSA733 in the 120-240 range
Q902 - SM says MPS9484, found
2SA661O, replaced with KSA916Y
Main Amp Board
Q803/813 - SM says
2SA682 (or A777), installed was
MPSA56, replaced with
KSA916Y
Q806/816 - SM says
2SC1382 (or C1567), installed was
MPSA06, replaced with
KSC2316Y
Q805/815 - SM says
2SC372, installed was 2SC372, replaced with
KSC1845P
Q808/818 - SM says
2SA495, installed was 2SA495, replaced with
KSA992P
Q809/819 - SM says
2SA794 (or A682), installed was MPSA56, replaced with KSA916Y
Q804/814 - SM says MPS9630 (orC372), installed was 2SC372, replaced with KSC1845F
These are the thermal tracking bias Qs attached to the heat sink. Hopefully the 50mA rating won't be an issue here (C372 has 100mA). I didn't have correct pinout unless I went with something like the KSC2383. The Yamaha CA-800 used 2SC458 for the same purpose and those got replaced with the KSC1845, so...
After all that, I DBT'ed it, and reset the bias and DC Offset before hooking it back up. No pics though, forgot. It does seem to have more power/authority and cleaner presentation, so glad I went to the effort. Especially with that bad driver.
