HH Scott info
HH Scott pic
Wedweb,
Thanks for the pic. I don't have any specs for this receiver either. I'll probably end up getting the Service manual later than sooner. Yours will probably be gone by then.
Tcdriver,
Thanks again, Time for me to get to work.
Regards,
Eujohns
Well Eujohns,
I can't find the #@*% brochure!!
But I did some research. First off, my Scott is a 387, not 389. Stereo Review covered it in 1971. I believe the 25xx models are a little later. [edit: WRONG!!]
I couldn't find a pic of the 387 put got this of the service manual off ebay:
Edit: I found a reference to the 2502 & 2503 being reviewed by High Fidelity in 1968.
I remember a Scott tuner (it must have been in 1977 or so) with a punch card reader in it... It must have been for programming frequencies or so.
It also had a nixie tube display if I recall well. I can find nothing about it on the net. Does someone know the type? Any pic? It isn't even mentioned on http://www.fmtunerinfo.com
Thx..
Lucas
Eujohns,
Definely use the higher rated voltage electrolytics. Can't hurt anything and is safer than lower rated ones.
All others out there:
I have a Scott R 376 also, and very much enjoy the sound quality of it. The unit is stock.
I am considering upgrading it with new caps in the power supply and replacing the caps in the signal path with metallized polypro. Does anyone have a service manual for the R 376 they would be willing to provide copy of? I would pay reasonable cost for copying and mailing.
I don't remembe the model # but remember the tuner. They appear on eBay and seem to do so in spurts. Pretty unless the cards come with the tuner other than as a manual mode tuner. Think the cards were the mini-IBM/Holorith card. Back then there was some interesting engineering going on even if the sonic results were somewhat disappointing.
