jaygee
I thought this wasn't possible but now I'm not so sure. You can get 24/192 audio from the blu-ray's analogue outs into your 2 channel amp but what if you use a high end dac? 24/192 will NOT be output from your blu-ray's optical/coax out. It will be from HDMI but no dacs have HDMI inputs that I know of so I thought a high end outboard dac could be of no use with blu-ray.
Well do a google search on this company - allaboutadapters - and look up audio products. They sell HDMI converter boxes which go between your dac and blu-ray player. You connect your blu-ray HDMI output to the HDMI input on the converter box. You then connect either coax or toslink from the converter box to your dac and voila - your 2 channel analog system is now HDMI compatible. But I wonder if the full res 24/192 makes it to your dac?
This seems like a wonder product to me but I'm wondering if it's too good to be true! Can/does this work? Has anyone heard or tried these boxes? I'd be interested to know your opinion.
