Hickok 532 versus Seco 107
sopranojam85
I have a Seco 107 that I recently rebuilt, and it works reasonably well. However, it has some quirks that I'm still trying to figure out.
I came across a listing for a Hickok 532. It's in stock shape, needs work no doubt. Is the Hickok 532 going to be a better fit for testing DMC than the Seco?
The Seco says it tests DMC. I've heard that it's not so great for matching power tubes, though.
The Seco has a load pot that ranges from 0 to 100. I'm not yet 100% sure what this does. I thought that it applied a voltage to the plates, but the schematic is so difficult to read, I can't tell what it's actually doing.
Thoughts are appreciated. Thanks!
Hihckok's are generally considered one of the gold standard tester brands. The 532 is an older machine that may not test all the newer tubes. And yes it will need a restore/refresh. I have a 533. It's been calibrated and restored, and I have a calibration/test tube that I use to insure accuracy. I also have a CA-4 adapter that can test newer tubes including Compactrons. Best of both worlds...
The SECO 107 does NOT test power tubes for mutual conductance - only emission. Small signal tubes are tested for DMC. I have found that mine correlates nicely with a Triplett 3444 on 12AX7s, less so on 12AU7s and 6CG7s.
