Fitzgreen505
Member
So, I was trying to "fix" my Hickok 6000A tube tester and I put a multimeter across the leads of the meter.
Ouch. The meter was exposed to the voltage of the DMM and doesn't work any more. Flips to max with just a tiny bit of AC.
So, I was wondering if anyone knew:
1) a way to fix the meter and make it return to normal?
or, 2) what would be a sane replacement (not the $200 meter) for a the Hickok 6000A meter. The manual says it's a 0-100 microamp, 66K meter. Will anything with those specs work as a replacement?
