pixelriffic
Just bought this tester from Ebay. It was sold as serviced and calibrated. I was tested a number of known good 6CA7s, and it consistently showed about 5 ticks below the value in the guide. Worth noting that these tubes have been checked by two other testers. Small signal tubes, 12AX7s for example, behave as expected. For the power tubes, I have discovered that if I use the line adjust with the tube instated, I then get the expected reading. What makes me a bit crazy, is that I let go of a 539C a couple of years ago that behaved exactly the same way. No claims of calibration or service were made on that one. And yes I know, line adjust is intended to be done without a tube installed.
My dilemma is whether or not I should return the unit. Thoughts are appreciated.
