My SCA35 is long gone.
If I started from scratch again ( that is, non/ semi non working version needing a little to a lot of tlc) Dave's continuing evolution of it and Jon's nice casework would be a nice option.
Thinking aloud, I think I'd like 4 ohm as well. If the power jack had the built in fuse it'd save some space. I haven't had any tape decks in 30 years as well. I wouldn't lose sleep over no tape monitor.
Clearly each user has his own wants and needs.
BuzzK,
Good thinking and great ideas. But I have suggestions on two points.
1. I believe a lot of people will want the option to use 4 Ohms speakers, so, “Ground, 4, and 8 Ohm” outputs per channel (unless this is just for your personal use).
2. Are you thinking of using a small IEC C7 receptacle for power entry? No room for a C13 that will fit all those standard and exotic power cables out there? If not I would opt for the attached power cable using a nylon cord grip like these. https://www.elecdirect.com/media/specsheets/NPT-Dome-Cap-Cable-Gland-Connectors.pdf
Don't forget that "tape out" will frequently be used to record with a computer. What is needed is some kind
of buffering.
Problem is, the SCA only offers 8 & 16 ohm taps.
Yes, i bought one and disassembled it. ( ebay 3 years ago)Somebody made a buffer output for a pas3 using existing voltages and an op amp a while back . I don't remember the implementation![]()
You don't need additional RCA connectors, just a buffer to the existing "tape out".Peter -- I kinda like the idea of a buffered preamp out. Question: Would it be worth swapping that for one of the Aux inputs, leaving only two?
Problem is, the SCA only offers 8 & 16 ohm taps. I think if I went through the trouble to design and prototype one for myself, I might as well make some for others.
I like the idea of a detachable power cable, but YMMV.
If you can wait and pay the bill dynakitparts have a 4 + 8 ohm replacement transformer.I forgot it didn't have 4 ohm taps.
I don't remember seeing a 16 ohm speaker in over 30 years so it wouldn't be necessary for me.
I also forgot no dc filament to work with. Like I said it's long gone . Sorry about the sidetrack.
I appreciate the thought. I'm not revisiting this project. Its a nice little amp. I enjoyed when i had it. The things that are improving it here wouldn't get it back in the rack though. I still enjoy Dave's articles and always get something out of them.If you can wait and pay the bill dynakitparts have a 4 + 8 ohm replacement transformer.
https://www.dynakitparts.com/shop/z-565-output-transformer/
I sort of have a pipe dream to build a from scratch ( an ST35) with the audio regenesis efb boards like njcanuck did a while back. Two things holding me back is lack of time and lack of need.I think the main point of interest is how common and available these are, compared to the Stereo 35 amp.
